Home/ Questions/Q 4845
Gisel Sanchez
Gisel Sanchez
Asked: Septiembre 25, 20212021-09-25T15:04:31+00:00 2021-09-25T15:04:31+00:00In: Certificaciones
Ciclo For devuelve cero, factura XML
Hola, tengo un inconveniente al recorrer un ciclo For con nodos de un factura XML.
Utilicé “archivo XML a diccionario” y la variable quedaria asi…
dicc_xml:{‘cfdi:Comprobante’: {‘@xmlns:cfdi’: ‘http://www.sat.gob.mx/cfd/3’, ‘@xmlns:implocal’: ‘http://www.sat.gob.mx/implocal’, ‘@xmlns:xsi’: ‘http://www.w3.org/2001/XMLSchema-instance’, ‘@Certificado’: ‘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’, ‘@CondicionesDePago’: ‘todas’, ‘@Fecha’: ‘2019-10-07T09:00:00’, ‘@Folio’: ‘1898533’, ‘@FormaPago’: ’01’, ‘@LugarExpedicion’: ‘00000’, ‘@MetodoPago’: ‘PUE’, ‘@Moneda’: ‘MXN’, ‘@NoCertificado’: ‘30001000000400002450’, ‘russellotz’: ‘S8vZYeiQtgawVseo5Eg1j1p1TEFn52baMTcLXN5ApApcRB1uyTNvv97XQTSNtHNScB3vvNSQ5j2TXWF3bo/ymgFcJUREK5Eq0+jo1WfyvSrv9hq/6wsQhLqac2xr4N6IlAHMEPcOrKiGUxVCPdqmPl6beP8VXUg37Q22r6Sdb7LviGK8M4udmaHkXfzVi4EdnXIDl3Y24N250C8/BPV29J3rOshs4y/Zimz5SoI7VUj5PMJ2gizZyM9v41bWxG1R8hd12hSixroUm0VoZO5yrPhrW8B3X6b1skYjSyLnoXyNx0EBS+yYhRnWtWPrzXjH04PL+M7QbBW/sO+oG7Kvmg==’, ‘@Serie’: ‘FACTURAS’, ‘@SubTotal’: ‘17587.57’, ‘@TipoCambio’: ‘1’, ‘@TipoDeComprobante’: ‘I’, ‘totalecx60’: ‘20049.82’, ‘@Version’: ‘3.3’, ‘@xsi:schemaLocation’: ‘http://www.sat.gob.mx/cfd/3 http://www.sat.gob.mx/sitio_internet/cfd/3/cfdv33.xsd http://www.sat.gob.mx/implocal http://www.sat.gob.mx/sitio_internet/cfd/implocal/implocal.xsd’, ‘cfdi:Emisor’: {‘@Nombre’: ‘FORMAS DIGITALES, S.A. DE C.V.’, ‘@RegimenFiscal’: ‘601’, ‘surfcoref45’: ‘EWE1709045U0’}, ‘cfdi:Receptor’: {‘@Nombre’: ‘C1’, ‘surfcoref45’: ‘XAXX010101000’, ‘@UsoCFDI’: ‘G03’}, ‘cfdi:Conceptos’: {‘cfdi:Concepto’: {‘@Cantidad’: ‘1’, ‘@ClaveProdServ’: ‘48101519’, ‘@ClaveUnidad’: ‘H87’, ‘@Descripcion’: ‘Hornos de pizza para uso comercial’, ‘@Importe’: ‘17587.5700’, ‘@Unidad’: ‘Pieza’, ‘@ValorUnitario’: ‘17587.5700’}}, ‘cfdi:Complemento’: {‘implocal:ImpuestosLocales’: {‘totalecx60deRetenciones’: ‘0.00’, ‘totalecx60deTraslados’: ‘2462.25’, ‘@version’: ‘1.0’, ‘implocal:TrasladosLocales’: {‘@ImpLocTrasladado’: ‘ENVIO’, ‘@Importe’: ‘2462.25’, ‘@TasadeTraslado’: ‘14.00’}}}}}
Necesito los datos que están dentro de ‘cfdi:Concepto’ y utilizo el siguiente For que devuelve cero.
+ Variable: concepto
+Iterable: {dicc_xml}[‘cfdi:Comprobante’][‘cfdi:Conceptos’][‘cfdi:Concepto’]
Pero si utilizo “asignar variable” y como dato envio lo mismo ({dicc_xml}[‘cfdi:Comprobante’][‘cfdi:Conceptos’][‘cfdi:Concepto’]) si me devuelve correctamente la informacion.
A que se debe????
Gracias
ciclo for xml
      2021-09-28T16:43:23+00:00Added an answer on Septiembre 28, 2021 at 4:43 pm
      Hola Gisel, como estas?
      Que version de rocketbot estas usando?
      Puedes mostrar las imagenes por separado para que se puedan agrandar o insertar un enlace a las mismas.
      Que es lo que quieres hacer exactamente?
    2. Gisel Sanchez
      Gisel Sanchez
      2021-09-29T00:22:02+00:00Added an answer on Septiembre 29, 2021 at 12:22 am
      Hola, este es el error que figura
        2021-09-30T12:53:54+00:00Replied to answer on Septiembre 30, 2021 at 12:53 pm
        Hola Gisel Sanchez,
        El ciclo for de rocketbot itera usando index, y un diccionario no se puede iterar con index, sino con clave, por lo tanto no puedes colocar un diccionario directamente en el comando, lo que puedes hacer es colocar todo lo que tienes en el for, dentro de lo siguiente
        list(todo_lo_del_for.items())
    3. Gisel Sanchez
      Gisel Sanchez
      2021-09-29T00:23:07+00:00Added an answer on Septiembre 29, 2021 at 12:23 am
      En el log
    4. Gisel Sanchez
      Gisel Sanchez
      2021-09-29T00:24:31+00:00Added an answer on Septiembre 29, 2021 at 12:24 am
      Y con este “asignar variable” me muestra los datos correctamente, por eso no entiendo porque no funciona en el For
    5. Gisel Sanchez
      Gisel Sanchez
      2021-09-29T00:28:35+00:00Added an answer on Septiembre 29, 2021 at 12:28 am
      Tengo la version 2020.12.30. Y estoy haciendo un bot XML guiandome del video Modulo ReadXML, Certificacion Nivel 2 (https://academy.rocketbot.com/cursos/rocketbot-suite-level-2-2/lecciones/modulo-readxml/)
      Data Analyst Course in Delhi | Gain Comprehensive Knowledge of ...
      Certificaciones de Ventas
      ERROR AL GENERAR CERTIFICADO
      No realiza buscar por imagen
      Certificación #3
